Wheeling bear or... front
Hello,
I'm having an issue with my front side passenger suspension..
- growling in roundabouts, going left
- -.8 camber max, according to the alignment guy. Zero toe. The other side can get up to -1.5 (or a few points more)
- when I have the car jacked up, there is play in the wheel. I can shake the wheel side to side but not in a vertical position.
I know the growling is from the wheel bearing.. but could a bad wheel bearing cause camber issues?
Car was purchased a few months ago, 01 100k miles.
Bearing is most likely result of an accident, you might have a bent knuckle or control arm.
Figure out what's bent first then replace the bearing, you don't want to replace a bearing then find out the knuckle is bent and have to do that work all over again.
Wheel bearings can go bad with, or without accident damage. They do wear out with mileage. Also, if you have play side to side, but not top to bottom, then you have a bad inner, or outer tie rod end. The bearing may have just started to make noise, but might not have any play in it just yet. No a wheel bearing cannot cause camber issues, if you let the bearing get so bad that its causing camber issues, then your wheel is falling off lol.
I will report back later.
