VSA issues after Ohlins Install
After diagnosis found that VSA couldn't cope with the upped cornering abilities. +10 mph in my test corner. Especially on a more aggressive alignment, it can vary with setup. Mine appeared after fresh alignment new 200tws and a Js type wing was added. I also run a rear ap1 sway so the rear is more sensitive to trail braking. Every setup is different too. If your on the 10k 8k offering maybe play around with the settings more. Also find some long high way cloverleafs entrance exit ramps and try and listen to which wheel is being affected.
Could play around with going more soft or full stiff to see if it affects it. I just turn mine off unless it's raining as it will interfere.
Received 1,377 Likes
Turn VSA off
The following 2 users liked this post by B serious:
Bullwings (04-11-2024),
Viscousrealtime (04-10-2024)
alfman240z
04-24-2008 01:25 AM
-Yz-
05-12-2004 09:01 AM
