tires and oversteer
If I were to get 205/55/16 tires in the front and 245/45/16 tires in the rear of my ap1 will it help out with the oversteering and edgy handling characteristics of the car? This on stock wheels.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Yes but its hard finding 245/45/16 tire. You're left with not so great tires. All the stickiest 16 inch tires at 225/50/16 and will vastly out grip the 245.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
wider tire sure provides better grip/
but it also usually make gripp loose less progressive - and this is not good.
is your pressure good? (IMO should be 35 -38 on hot)
did you add camber at rear axle?
