Tein Flex Creaking Noise (Bearing?)
Hey guys,
Long time lurker, been having a problem with my Tein Flex coils - rear passenger side. I took it to the mechanic and he said the bearing is loose where the coil body bolts onto the chasis. When he push down on the trunk, there is visible play where you adjust the damper. I was wondering if anyone has gone through this issue and if you could point me in the right direction to fix the problem.
I've searched through the forum/web for the past few hours to no avail.
Thanks guys.
B
EDIT: Looked around on the 350 forum and turns out that it is a common issue with the pillow ball mount on the TEINs.
Thanks guys.
B
jchung
25
10-23-2006 09:11 PM
