Tein Flex Coilovers
Tein Flex Coilovers
Does anyone else run these on their S? I have them on my car and the ride is terrible. I have the rears all the way down, and the fronts like 28 threads or so from the bottom. Ive been messing with the stiffness with the rears and fronts but have yet to find a good setting. Just curious what other people are running on their settings. I did a search but found nothing on what people were running setting wise. Hopefully someone can provide some input.
-D-
-D-
sorry i dont mean to thread jack but i have the same problems with my tein circuit RA's the ride is so hard my GF hates even sitting in my car... what can we do to make the ride softer. i might take it in to my garage to get a suspension tune.
OP
I have the same suspension which I installed a few years ago so my memory may not serve me well. I believe I have the front set at 4 clicks (from hardest setting) and the rear set at 8 clicks (from hardest setting). Also what do you mean when you say you "have the rears all the way down"? If you have it at the lowest setting then you may be bottoming out or not getting enough suspension travel. In that case I would adjust accordingly. Hope that helps some...good luck.
spring preload should be zero.
lowering shouldn't be too crazy (anhything more than 30mm is too much).
for comfort street ride you should be about 2-6 clicks from the softest.(10-14 clicks from stiffest)
I have had mine on for two years and personaly it feels better the stock i love mine. My buddy with pss9 on his car says he likes the way my flex feels he says its way better then his
