Swift Spec R!
#21
Originally Posted by Jumpman2k,Nov 22 2010, 10:06 AM
Here are some shots after putting the spacers in:
#25
Where did you order from to get the custom rates?
#27
When you lowered your car with the Spec R Springs did your driver side lower more than your passenger side?
I just lowered mine and my driver side is about 3/4 of an inch lower.
#28
I have considered doing the exact same suspension but worried about the rubbing issue too! This looks to be a great solution.
#29
I was lucky and a local guy who has a Dynatorch plasma cutter made them for me for no cost. In the end the thickness was actually 3/16", I believe. But naturally if you have them made you can dial it to your needs. If you go too thick, though, you may need longer bolts for the upper mounts. Especially if you have a strut tower bar.
#30
Originally Posted by Pinky' timestamp='1333988152' post='21590283
Where did you get the spacers made? How much was the cost?(please send or post info.)
