Sponsored by: Sake Bomb
sway bar
Old 01-16-2012, 12:52 PM
  #21
ScandinavianFlick's Avatar
You're correct about that- I'm running 0 front toe and 1/16" total rear toe in, -3.5*F/-3*R camber, and rear rebound stiffer than front, all of which contribute to a generally oversteery setup. The easiest and most consistent way to change between oversteery balance (desireable for autox) and neutral/slightly understeery (better for road courses, especially with my fairly novice skill set) is to swap the rear bar.
My point was that the Eibachs allow a great range of adjustability in setup, even for a staggered car; something that a large Whiteline or Saner FSB may not grant you.
Old 01-16-2012, 01:04 PM
  #22
S2k007's Avatar
Originally Posted by Croc
here:
http://sites.google.com/site/crocweb...onda-s2000-faq
for a non staggeed setup perhaps beefier sway bar (Sanner) is better...
Thanks. Although, I'm not familiar with reading those figures. How much stiffer is the eibach bar in comparison to the my00 bar.
Old 01-16-2012, 03:41 PM
  #23
Banned
vividracing.com's Avatar
Originally Posted by S2k007
Originally Posted by Croc' timestamp='1326704585' post='21320557
here:
Have you tried running with the rear sway bar disconnected? That might be enough to get the car to behave the way you want.
Old 01-16-2012, 04:55 PM
  #24
S2k007's Avatar
^ I thought about that. Would you guys recommend Eibach front, rear disconnected for an AP1 with the following:
255 all around, 17x9 wheels.
Bilstien PSS9
I was also thinking of softening up the dampening on the rear of the Bilstein as well as more camber in the rear (2.5r, 1-1.5front).
Old 06-22-2014, 12:45 AM
  #25
min0527's Avatar
Originally Posted by nmrado
For auto-x, people typically get a stiff front anti-roll bar and find a softer rear anti-roll bar. Many of the STR participants use the '06+ NC Miata front anti-roll bar in the rear of the S2000 or no rear anti-roll bar at all. What auto-x class are you building to?
Choosing an anti-roll bar setup needs to be properly selected based on spring rates and tire sizes. Any other modifications to your suspension system?
What about your current setup do you dislike? What characteristic is pushing you towards anti-roll bar changes?
Bill2K
06-24-2012 10:47 AM
scirocco25
07-21-2008 05:23 PM
G2k
03-02-2007 06:32 AM
all-trick'd-out
05-10-2004 08:15 AM
t.c.
01-15-2003 02:39 PM
Quick Reply: sway bar
