Sponsored by: Sake Bomb
sway bar
Old 01-13-2012, 06:23 PM
Former Sponsor
Moddiction's Avatar
I don't think there are any no name front sway bars. At least not that I have seen.
Old 01-14-2012, 01:50 AM
TTMartin's Avatar
Originally Posted by nmrado
Originally Posted by TTMartin' timestamp='1326329682' post='21308495
Running a staggered set-up there is no reason to disconnect or go to a softer rear sway bar.
For an AP2, agreed. For an AP1, I think the added front roll stiffness is beneficial.
Umm, here's the other half of my post that you didn't quote:
A stiffer front sway bar should reduce body roll.
Old 01-14-2012, 02:11 AM
TTMartin's Avatar
Originally Posted by erikvanden
Originally Posted by nmrado' timestamp='1326412885' post='21312032
[quote name='TTMartin' timestamp='1326329682' post='21308495']
ok well what sway bar would be the best bang for the buck? Do I need to spend lots of money? or will an ebay bar be good enough?
[/quote]
Best bang for your buck, would be a Eibach 32mm Front Sway Bar at $180.
Old 01-14-2012, 03:07 AM
Croc's Avatar
i was afraid that beefing up just front bar would upset the ballance by bringing too much understeer - so i went for front and rear bars.
and it worked well indeed.
Eibachs are probably the best bang for a buck.
F+R costed me [just] 335$ a set shipped.
Old 01-15-2012, 10:20 PM
S2k007's Avatar
Anyone have the specs on the Eibach bar versus stock and saner bar?
I'm going with a square setup on an AP1, looking to add eibach front bar.
Old 01-16-2012, 12:03 AM
Croc's Avatar
here:
http://sites.google.com/site/crocweb...onda-s2000-faq
for a non staggeed setup perhaps beefier sway bar (Sanner) is better...
Old 01-16-2012, 05:42 AM
Former Sponsor
Moddiction's Avatar
Saner bar is definitely much beefier. However they are no longer made so only option is a used one. Gendron seems to be the best but much more expensive!!
Whiteline seem to be pretty good bang for the buck sway bars.
Old 01-16-2012, 08:56 AM
Rubn1out4GudLuk's Avatar
Currently have Cusco 32mm front sway bar...Cost me around $300(by no means a cheap option but the quality of the bar is up there
Old 01-16-2012, 09:35 AM
ScandinavianFlick's Avatar
I'm currently running Eibach F&R bars with KW V3s and 235/255 stagger RE11s. I have the front bar on its stiffest setting and the rear on its softest, which maintains the front-to-rear rate ratio of the stock bars. I'm very happy with the setup for autocross; however, it's almost unusable on the street and too oversteery for big tracks. Fortunately, it's easy to swap the stock rear back in when a more nose-led balance is desired.
Old 01-16-2012, 12:04 PM
Croc's Avatar
IMO your ovesteer doesn't come from the sways - it's from somewhere else from your setup.
Quick Reply: sway bar
