Sponsored by: Sake Bomb
sway bar
Old 01-11-2012, 10:47 AM
erikvanden's Avatar
Default sway bar
I was wondering if I should purchase front and rear sway bars. I have an 01 and from my understanding they are already stiff. I do autox though and I know a lot of people with S2Ks have recommended sway bars. any thoughts on them?
Old 01-11-2012, 11:24 AM
User 121020's Avatar
For auto-x, people typically get a stiff front anti-roll bar and find a softer rear anti-roll bar. Many of the STR participants use the '06+ NC Miata front anti-roll bar in the rear of the S2000 or no rear anti-roll bar at all. What auto-x class are you building to?
Choosing an anti-roll bar setup needs to be properly selected based on spring rates and tire sizes. Any other modifications to your suspension system?
What about your current setup do you dislike? What characteristic is pushing you towards anti-roll bar changes?
Old 01-11-2012, 12:13 PM
erikvanden's Avatar
I have stock suspension with 17in wheels. 225 front 255 rear. I really just wanted to decrease roll and get better times. I just know a lot of people who have got new sway bars have said it helped a lot. They have newer S2Ks though.
Old 01-11-2012, 03:54 PM
TTMartin's Avatar
A stiffer front sway bar should reduce body roll.
Running a staggered set-up there is no reason to disconnect or go to a softer rear sway bar.
Old 01-11-2012, 08:33 PM
Croc's Avatar
i'm happy with Eibach sways.
Old 01-11-2012, 09:07 PM
Carbon Blue's Avatar
Im in the same position as you except ive got bilstein pss's and stock sized ap1 wheels. I want a stiffer front sway but dont want more induced understeer.hmmmm
Old 01-11-2012, 10:13 PM
Back S2k's Avatar
i think this is impossible to achieve if the only variable u r changing in ur set up is a stiffer front bar.
Old 01-12-2012, 08:55 AM
Alignment can be used to negate understeer when adding front roll stiffness. Less rear camber, more front camber, less rear-toe in...these will all promote less understeer.
Old 01-12-2012, 03:01 PM
For an AP2, agreed. For an AP1, I think the added front roll stiffness is beneficial.
Old 01-13-2012, 06:13 PM
erikvanden's Avatar
ok well what sway bar would be the best bang for the buck? Do I need to spend lots of money? or will an ebay bar be good enough?
Quick Reply: sway bar
