Stock/Koni to Swift/Koni Review
Originally Posted by Carbon Blue' timestamp='1337282289' post='21707474
[quote name='chubbychu' timestamp='1337244246' post='21705864']
[quote name='Carbon Blue' timestamp='1337231248' post='21705596']
thanks for the info, but what wheel and tire setup are you on?
[/quote]
Well, after all the front spring rate is only 250 something. I mean, I weigh almost that. Haha. I went ahead and had the front tabs bent in, and that seemed to alleviate some of the problem. It's basically rubbing fender liner now under extreme cornering.
[/quote]
Did you already max out your camber? You didn't mention that and negative camber is the easiest way to help your issues.
