Stock Alignment Question
So I just had my car aligned and this is how it came out, I didn't think much of it at the time but I am thinking I may want to have the caster remedied.
Here are the specs:
Camber: -1.0/-0.9
Caster: 4.5/5.5
Toe: 0.00/0.00
Camber: -1.5/-1.5
Toe: 0.12/0.17
Is that caster okay for the front? I believe it was originally set up that way to compensate for the road crown, but I'm not sure if I'm better off with it evened out. Both are out of spec (5.8 to 6.3 is stock) so I'm concerned a little with the 4.5.
The car is on stock suspension and the Camber is set per my taste (additional camber up front.)
Here are the specs:
Camber: -1.0/-0.9
Caster: 4.5/5.5
Toe: 0.00/0.00
Camber: -1.5/-1.5
Toe: 0.12/0.17
Oh I realize it's off from factory (5.8 to 6.3) I was just concerned with it being too far out, which I think it is. I'll probably swing back by and see if they can take a look at it again.
Just got off the phone, both are maxed in their opposite directions, the right is as far back and the left is as far forward..... I left before the tech had a change to talk to me. He's thinking it may be a bent/tweaked lower control arm on the driver's side.
eremoy
04-12-2014 06:27 PM
