Still vibrating in rear after both axles replaced.
Still vibrating in rear after both axles replaced. Spacers were installed next still vibrating. Could it be diff mounts? I don't see any leakage. Also vibrates when I'm around 80mph & all tires have been balanced & alignment done. I'm lost as to what to do. Maybe a little gasoline & a match will help. That usually fixes my Honda problem.
Originally Posted by Davidletran,Dec 22 2010, 06:20 PM
I got the same problem. Both axles were changed and still got a small vibration. Gonna grab some of those spacers. Could be a wheel bearing also.
I had this issue like this after bearing and axles were changed. Turns out it was the after market axles. I guess they rebuilt oem ones but shaved it by turning the shaft. Shaft was like a toothpick compared to the oem one.
