Spring Pre-Load
#21
Would you agree that bushing pre-load will achieve a spring pre-load as well?
This seems to be a good illustration of spring preload: http://zilvia.net/f/tech-talk/58103-...tml#post513617
Kinda sorta, Not fully. Because the bushings themselves aren't strong enough to peform a "spring action" IMO.
#22
If the lower control arm is being jacked up enough to lift the car off the jackstand w/ the coilover in place, I'd say there's some spring action there. I'd say what...about 600 lbs or so?
#23
I wouldn't think near that much. But I could be wrong. Maybe someone else has some insight? lol
#25
In the air...ergo, no pressure/flex from the other side...in this scenario the car's wheels are all off and all 4 corners are on stands.
#27
sway's intact and connected, I've never disconnected it. 20 lb/in sounds a little low to me.
![ponder2.gif](https://www.s2ki.com/forums/images/smilies/ponder2.gif)
#29
Hey mac, would you run through the process for us? I'd like to hear your procedure on this as well.
#30
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I've started a post but didn't get too far but I'll continue with it.
Here's the link although it won't work just yet.
https://www.s2ki.com/s2000/topic/953...gs-incomplete/
PLYRS 3
03-01-2008 12:08 PM
