Sponsored by: Sake Bomb
Skunk2 spring rates and Koni yellows Combo
Old 01-23-2011, 02:44 PM
02_s2k's Avatar
Default Skunk2 spring rates and Koni yellows Combo
I purchased my car with it already lowered with skunk2 lowering springs on stock shocks. Well, I plan on upgrading to some Koni Yellows, however is it a waste of time? Should I save up for some Coilovers? I dont daily drive the car. Its not even a weekend car. My goal is to be able to take it to the track once or twice a year and enjoy it on twisties every 3-4 weeks. What are the Skunk2 spring rates? Also does anyone have similar experience to this setup?
Old 01-23-2011, 05:17 PM
robinson's Avatar
Koni make great shocks. The springs you have, are not great. You would be much better off getting Hyperco springs and a sleeve if you went the route of the koni, thus making a coil over suspension (which is technically what you already have anyway). Let me know if you have more questions, I have a DA (double adjustable) set of koni shocks and I also have sleeves.
Old 01-23-2011, 05:30 PM
02_s2k's Avatar
You have the DA setup for sale or in your car?
Old 01-23-2011, 06:30 PM
robinson's Avatar
No, I just have it and therefore I can offer assistance to others with Koni shocks.
Old 01-23-2011, 07:04 PM
02_s2k's Avatar
ANd are these for sale or in ur setup?
Old 01-23-2011, 07:05 PM
robinson's Avatar
Good grief man, I have them, they are not for sale, I can help you.
Old 01-23-2011, 07:09 PM
02_s2k's Avatar
HAHAHA!!! Ok. I wanted to be sure that's all. LOL!!! So what kind springs would you recommend? I looked at the ones you mentioned before but do you know what model it is? Cause i looked through their catalog and there were no vehicles matching certain numbers.
Old 01-23-2011, 08:16 PM
hypforlife32's Avatar
i just installed swift spec r springs and my car is daily driver. i have noticed over regular bumps it feels like oem and over larger ones it is noticeably stiffer. all around great springs. i would definetley pair this up with a set of konis.
Old 01-23-2011, 08:18 PM
robinson's Avatar
That's because you pick a spring rate and diameter to fit your needs. You will be able to use 2.25 inner diameter springs. If you just want a stock like ride pick stock rates in 8 inch lengths if you want to lower your car.
Old 02-21-2011, 11:52 AM
bsyeth's Avatar
Im not sure of the answer...
But Does Anyone Know of the Correct Answer for the Question?
what is the spring rates of the skunk2 lowering springs?
Quick Reply: Skunk2 spring rates and Koni yellows Combo
