SBG FPSport vs stock Ohlins question.
I have the FPSport. It’s ok. I would probably just do stock ohlins if I were to pick between the two. They’re not different enough for me to want to sell mine for stock though. The FPSport has a tough time controlling rebound on the rear spring and that requires running very high damping on the rear - near full stiff - to maintain rear end stability. With full stiff setup it starts to work but you are definitely losing time on the track vs a staggered spring setup. I linked a video to how it drives with a 32mm front bar.
To be clear I don’t think it’s valved well for the rates and I definitely would not put any stiffer of a rear spring on the FPSport. been considering either revalve w Urge and a 12/10 setup or to upgrade to 2W karcepts MCS setup
https://youtu.be/i51Al2OWb0c
If you’d like to revave to our FPSpec Curves and spring rates, hit us up, happy to help get you where you’d like to be at a discount. Our valving lab is internal in house (Ohlins certified Motorsports Distributor and Service center). We can turn around a revalve with our race winning FPSpec Curves in just a few days. If you’re in Northern California, we can even pull the shocks out of the car, break them down, off to the valving lab on site, and back on the car, set up and aligned. We strive to support our customers for the lifetime of their Ohlins. Info@SakeBombGarage.com
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
I've had the FPSport Ohlins DFV since 2018. I've never driven on the Karcepts MCS or the standard Ohlins DFV (10k/8k), although I've sat passenger in a car with the latter. So unfortunately, I can't comment on the driving performance of these vs. the FPSport version.
My reasoning behind getting the FPSport over the standard Ohlins was to have the ability to fine tune the spring rates up or down without revalving. I believe the FPSports can accommodate as high as 14k without the need for a revalve.
My suggestion for a primarily street driven daily S is to get the standard Ohlins DFV and spend the little extra on getting the remote adjusters for the rears, if you still have your rear trunk panel covers. It makes adjustments much quicker and easier.
__________________
