S/S brake line change question
I am getting ready to put a set of Endless S/S brake lines on my car and wondered if I could remove/install/bleed in the order of the bleeding process? Or am I going to have to remove all lines, then install, then go back and bleed seperately? Prolly a stupid question, but this will be first attempt at this install.
Make sure you burp the calipers while bleeding. Often times, air gets trapped in the crevices in the calipers so you will need to bang it with a rubber mallet. Now is also a good time to throw on speed bleeders.
