replacing front brake pads
I replaced the front passanger side fine, as I do the drivers, I loosen both bolts, replace pads but I can't compress the top slider pin. The bottom one pushes in fine but the top doesn't. Anyone have any suggestions I can try when I get home? It's supposed to be really nice on Thursday up here and I'm hoping I can get it moving without having to order anything so I can drive top down Thursday instead of the other car.
Thanks!
Thanks!
You need to lube your pins, you should be able to get it loose by twisting it with a 19mm socket assuming the caliper is off or a 19mm wrench if it's still on.
https://www.s2ki.com/s2000/topic/921...liper-refresh/
stainbow1
05-15-2004 05:15 PM
