Rebuilding Rear Calipers - I need help!
Hey guys,
Im currently in the middle of rebuilding my rear calipers with the seal kit and the DIY on here. Im having trouble though....
How in the hell do I remove the Ebrake piston??! I just cant get the bloody thing out at all! The part I am on about is the grey one in the top left of this photo.
Any help would be brilliant!!
Ad
Ad
I assume you've done the hard part already and removed the circlip, spring cover, spring, spacer, bearing, adjusting bolt. Then you just smack the caliper against the ground and it falls out. Don't lose the little pin behind sleeve piston.
Getting the circlip out is 99.9% of the battle. Snap ring pliers from NAPA with long extensions is the key tool here.
