rear left brake makes noise and vibrates car
recently my abs light came on, the noise coming from my rear left brake side so i took it to get checked out and my rear left speed sensor was bad so i replaced that and the light came off, but the brakes still screech and itll vibrate the car depending on how i brake, if i brake normal itll vibrate so ill let off and apply the brakes again so it would stop, any ideas what it could be? maybe need new pads or rotors? thanks ahead of time
Things to check: pads worn to wear-indicators (metal flap that scraps rotor to make noise and warn you pads are worn out), unseated pad retention springs (they are shaped like butterflys), poorly greased pad shims...
