Quick question about coil overs and alignment
I installed PSS9s a few weeks ago. The rears came out perfect but the passenger front was 1/2" higher so I adjusted the coil over on the front passenger side 6mm lower to make it even. Now I'm about to get an alignment. It was on Swift Spec-Rs before and aligned but curious if the new alignment might have a big effect of ride height. I don't want the passenger front to come out too low after. How much does alignment affect height if any?
Everything was per-loaded properly before tightening bolts.
Thanks!
Thanks!
Alignment doesn't affect height, but height affects alignment.
Also, any twist in the car can't be adjusted out with coilovers. I.e., if on a flat plane the distance from rear wheel centerlines to the fender are the same, and the passenger front is 1/2" higher vs. the driver's front, that's twist in the fixed chassis/body of the car (not uncommon, but 1/2" seems a lot). You can't lower just one corner. If you adjust the passenger front to lower it, you also lower the driver's front and to a lesser degree the passenger rear.
Tomorrow I get an alignment. I have almost 1,000 miles on the setup so they should be settled well by now. All struts are set on #3 for damping and I like the way it feels.
Thanks for the help...
You'll probably want to check corner weights, too.
Good idea and you're correct. Right now I think I'm ok. No weird driving aspects to worry about with the car. Once I get more into track events (more than 2 a year) I'll put more effort into getting it dialed in. For mostly street driving it's fine for now.
chuhsi
08-01-2010 10:28 AM
notyourfriend
03-12-2009 01:31 PM
