View Poll Results: Where do you measure from to get equal standing height?
Voters: 7. You may not vote on this poll
Proper Wheel Gap
Proper Wheel Gap
It seems as though when measuring wheel gap, I get an equal 13" all around after my drop. Although, the finger gap is different (1.5 fingers up front/1 finger in the back) What should I be setting the ride height to?
1. Equal finger gap
2. Equal wheel gap
1. Equal finger gap
2. Equal wheel gap
- size of fingers
- camber settings
- rolled or non roller fender lips
- front or rear fender lips
- tread wear
- etc, etc.
So, finger gaps are an inconsistent unit of measure. It's impractical to compare "finger gaps" from one car/owner to another.
Wheel center - to - fender lip distances ("wheel gaps" as you refer to them) are:
- measured with a tape measure
- are mostly independent of camber settings
- are independent of rolled or non rolled fender lips (unless fenders are pulled/flared)
Just my 2 cents.
1. Equal finger gap
2. Equal wheel gap
1. Equal finger gap
2. Equal wheel gap
- size of fingers
- camber settings
- tread wear
- etc, etc.
Just my 2 cents.
Depending on lighting effects, less negative camber in the front could make it look like more of a gap...just a guess. If you're going for aesthetics, adjust the ride heights until you are pleased and use the measurements to even them out side-to-side.
