Project Kics Extended Wheel Studs
I'm looking for 10mm longer wheel studs than stock and the only company that I found that makes these is Project Kics. I know ARP are top notch in terms of quality but 25mm longer than stock will stick out too far (running a Stoptech BBK with a 3mm spacer and want to keep closed lug nuts). Also, it's a PITA to replace wheel studs so I don't want to install crappy ones only to redo the work xx miles later.
Anyone here running Project Kics extended wheel studs? How are they holding up? Any track or auto-X sessions with them?
Any other high quality extended wheel studs you can recommend that are 5-10mm longer than stock?
08s2000CRbackinblack
12-24-2010 06:44 AM
OneQuickS2K
09-13-2002 02:27 PM
