Pop noise
Pop noise
so i just put in elisper springs and tanabe sways and i love the setup btw, but recently when i am comming out of a slight turn at high or low speeds there is a loud POP noise comming from my rear suspension, like like the sound of a rock popping out of your tred, but i checked my tires and they are fine, i removed my rims and made sure the toes and cambers and springs and all that crap is nice and tight, HOWEver i DID not lube my sways when i put them in, but i dont know if this would cause such a loud "pop" like noise however everything is tightened and my mounts are fine so does anyone have any ideas? fyi i am running on stock shocks, ALSO the metal like sleave on the outside of the shock isnt rubbing against it either, so anyone have any ideas? at the end of this month im switching to koni shocks anyway but regardless i want to find out what this loud popping like noise is
Is it possible that your just paranoid now and the little popping noise was coming from the rear of the car all along? I think it could be the rear axle nuts not being torqued down enough if so. Either way, torque them to see... I can't remember what it has to be torqued to though.
