Sponsored by: Sake Bomb
Own KW variant 3?
Old 04-09-2013, 08:58 PM
p-p-porkchop's Avatar
Default Own KW variant 3?
How is everyone doing?! Just wondering if anyone is using softer rates than the out-of-the-box rates. I bought a used set for MY02 and they are still really rough over rocks and bumps compared to my OEM. It's set at 3 clicks from full SOFT at the top of the shock. I think its at 3 sweeps from full SOFT at bottom of shock. The damping is much smoother over larger bumps compared to OEM. The handling is noticeable improved and overall the car feels more planted. Anyways, any input would be appreciated. Thanks.
Old 04-10-2013, 03:37 AM
Croc's Avatar
mine came with 468 springs.
i think they're too soft.
i'm not sure how you count from full soft - you should turn it clockwise untill full close/stiff and that start from there.
i'm at 7/10 clicks rebound f/r (top adjuster) and at #3 bump (bottom adjuster).
from full stiff!!!
this is quite compfortable.
going 1-2 more clicks on top makes it really really soft (but too much body roll for me).
Old 04-10-2013, 06:30 AM
spdracerut's Avatar
Instead of messing with the suspension for ride compliance over 'rocks and bumps', you may actually want to change your tires. Some tires ride very rough (like the stock Re050s that came on AP2s, or Yokohamas in general) or very soft (like Toyos).
Old 04-10-2013, 08:48 AM
from full stiff!!!
I will readjust starting from the full stiff positions.
Come to think of it I never checked what the spring rates were. They came with tophats so I just popped them in. I believe I oveoooked the rates because they were faded or couldnt be read on the springs. I just assumed they were out-of-the-box spring rates.
How low are you? In terms of fingers or fender-to-center of the wheel measurents
Old 04-10-2013, 08:53 AM
You're absolutely correct! I have AP2v2 on some worn rears RE050
Im leaning towards the Continental DW. I would love to get a set of Pilot Super Sports or even Potenza RE-11A but those are so pricy!
Old 04-10-2013, 11:14 AM
ungucpho's Avatar
i'm using swift 10kg springs. mine came with 9kg, or 458 lb springs. i wish i would've gotten 12k
Old 04-10-2013, 11:49 AM
MrChoi's Avatar
I switched from 515 to 350 ft/in
Old 04-10-2013, 08:19 PM
Were you happy that u switched? Any pros and cons you would like to talk about?
Old 04-11-2013, 03:45 AM
subwayasian's Avatar
I do not like my v3s at all. Too soft for me. Will be selling my set soon.
Old 04-11-2013, 10:42 AM
Croc's Avatar
i felt the same.
and i drive hard.
sways and stiff bump setting made them good.
Quick Reply: Own KW variant 3?
