Sponsored by: Sake Bomb
Official Springs Thread
Old 02-23-2010 | 02:52 PM
  #371
alexdog1's Avatar
Has anyone run CR springs On their stock ap2 shocks ? I would be interested in hearing about the ride and handling. I autocross my 07. I want to improve handling without ruining daily driving or breaking the bank. I currently have a Cusco front sway bar and run 225's front 255'S rear. I have read decent things about Swift and am a little confused about the Eibach springs and whether or not they were designed solely for ap1's.
Old 03-06-2010 | 11:34 AM
  #372
gottaloves2k's Avatar
(noobie question)
Hi. I also had my Eibach Pro Kit and 15mm H&R wheel spacers for front and rear installed a week ago. After the installations, I have alignment done yesterday. I am very satisfied with the drop.
However, (I hope anyone can help me on this) I have one problem. Whenever I accelerate (or especially shifting from 1st to 2nd), the car front end, I believe, shakes (and, slightly pulling to the left). I got a new set of tires almost 6 months ago. And, I am a quite conservative driver, so I doubt that the tires are the causes of this problem. I am fairly sure that it is not the alignment (it coasts straight).
Anyone any thought on this problem?
Thank you,
Old 03-07-2010 | 03:35 AM
  #373
Civicvtec1ps's Avatar
ap1 kg/mm Race Springs on 08 ap2.
On stock shocks, which is fine.
But planning to upgrade with koni yellows later.
Tire Size
225/45/17 F
245/40/17 R
Old 03-07-2010 | 08:08 AM
  #374
tsturbo's Avatar
Can someone help me identify stock springs (fronts from rears) as they are very close. I bought a used set and will be converting my S back to stock springs. There are painted markings on the springs two of the springs have different markings from the other two (obviously) but I just need to find out which ones are the fronts and which are the rears. Any help, much appreciated!
Old 04-05-2010 | 09:50 PM
  #375
Edberg's Avatar
Originally Posted by S2k007,Feb 9 2010, 11:50 AM
What do you guys suggest between the tein s specs and Eibachs? They both have the same drop but how do they compare in terms of ride quality, spring rates, etc?
I'd like to know this too, also how do they compare on the track? Is it true that the Eibachs aren't progressive?
Old 04-23-2010 | 09:26 PM
  #376
encomium's Avatar
hi all, been reading through this thread and i am looking to lower my car which is an AP1 on stock suspension at the moment.
Current shortlist are
Tein S
Eibach
RS*R
My only concern is clearance/rubbing.
I'm running Volk SE37K's, 17" with et40 all round. 7.5J in front and 8.5J rear. Tyres are 225/45/17 all round too. I'm going to change the tyres, probably to 215/45/17 (front) & 235/45/17 or 245/40/17 (rear).
I don't want to have any issues with the arches and because of the sub-optimal offset of my wheels, I know this may be a problem. So, if anyone can lend any advice, it would be great!
Old 04-24-2010 | 08:11 PM
  #377
hellaSleepy's Avatar
what springs would give us the lowest drop? I had Espelir ASD's and want something just a little bit lower
Old 05-26-2010 | 09:55 PM
  #378
daverussell's Avatar
installed some neuspeed springs today pictures will come tomorrow
front=1 index finger gap
rear=tight 1 index finger gap
car has only settled for a few hours
the ride seems to be the same
Old 05-27-2010 | 07:49 AM
  #379
abstracthomie's Avatar
Neuspeeds dump the most and evenly.
Old 05-27-2010 | 08:37 AM
  #380
avarela86's Avatar
Tein S
Eibach
RS*R
Im in the same boat but am considering the CR springs as well to your list to help with the oversteer. Thoughts? Has anyone tried CR springs on AP1? Granted I wont be lower at all, I drive my car daily through really crappy roads though.
