OEM or custom alignment
So I have been wanting to get new tires and an alignment. Its my daily driver but want a somewhat ag gressive alignment thats not gunna eat thrumy tires much more than OEM. Im wanting to go with a little more camber so I can fit 255's in the rear. I might go with a re-barel on my front wheels so the fronts will be 17x9.5 +55 to match the rear. Or is that too aggressive in the front? My car already has a basic roll/ no pull all around.with the bumper tab relocated
But for now my setup is 17x8 +43 w/225/45- 17x9.5 +55. W/245/40 lowered so there is about 1 finger gap between tire and wheel well
What would be a good alignment for this? Because my car seems to be a little dull while handling compared to when I first got it.and compared to my friends S2000. When I first got my car I got a bit of oversteer compared to the pretty bad understeer im getting now
I have -1.5 camber up front with zero toe. In rear I have -2.5 camber with .2 toe in each side.
If your worry about tire life I say stay with -1.5 camber like said above and stay below .1 toe in rear.
-1.8f -2.0r
0 toe f .15 total toe r
max caster
I love my specs, car rotates and tires wear evenly
max caster
