New to coilovers, which ones would you recommend? Also questions about koni yellows
So I was thinking about getting coilovers and I have some questions about them.
I was looking at koni yellow shocks because of their price. If I got the shocks would I also need to buy springs? Also would they lower the car and would it be adjustable? And how do they affect handling?
And can anyone recommend some good coilovers, I am looking for some that are ride height adjustable, improve handling, and arent too expensive(if any coilover like that exist lol).
No
You can use the lower perch and lower the car by 1/2". No, that would not be adjustable, but, you can buy adjustable perches like Ground Controls to use with them with the Koni's.
Everyone has a different definition of "improve". For you to define it, you'll need to think about what you like and dislike about the current setup. The changes you make should retain the "like" features and improve upon the "dislike" features. If you dislike the stock ride height but like the comfort level of the stock suspension, for example, you'd want something with spring rates that were similar to stock that have the ability to lower the chassis. A TTMartin said, the Konis you're considering can lower the car about 1/2" to 3/4" using the OE springs. The threaded perches can be used with aftermarket coilover springs if you want to further alter the setup.
That said, my car had the most grip with spring rates similar to a CR, a stiff front anti-roll bar and 255/40/17 Hankook RS3s all the way around. The coilovers I was using at the time were the Bilstein PSS. But, it didn't do what I wanted for auto-x....so the spring rates had to increase substantially.
zeroptzero
01-14-2014 06:28 PM
unregistered
05-09-2003 10:27 AM
