Need help to choose brake pads
Hi guys, I am thinking to change rotors and brake pad the same time.
I was thinking slotted StopTech but I don't know what pads will go with StopTech and less dust and noise.
Thanks in advance
Thanks in advance
Slotted Stoptech rotors aren't a bad way to go. If you want better performing pads with less dust and noise the Street Performance pads are also a great choice. We sell packages that include this setup.
http://store.excelerateperformance.c...s/g-70937.aspx
If you don't mind a little more dust and want something with more bite I'd look into some Hawk pads.
http://store.excelerateperformance.c...s/g-50337.aspx
Sorry to barge in,
Would stoptech slotted rotors plus hawk pads be a good way to go for track use? I don't need a BBK, I don't care about noise level or dust, Just want the pads/rotors to handle the heat.
Thanks
Thanks
choose...but choose wisely
For what the OP is using the car for there is no reason to go with slotted or drilled rotors, a set of Centric blanks and OE pads would be the best choice.
