Need HELP!
Need HELP!
In fortunately a little over a month ago I took a sharp turn into to water an into a curb, I took it to alignment shop, they ended up suggesting to change my whole front suspension? I couldn't do that, so I asked what where the major problems He pointed out the lower control arm was bent an if that was bent, then so was the upper control arm an moslikly the spindle. I switched out the upper an lower. The damage is on the driver side by the way. I did not change then spindle, an I took it to get realingned? My cars steering wheel is slittlely turned to the right when going straight an goes off to the left when I let go of the wheel...... Is something else bent, if so what can it be? Please any info could help.
dan_uk
12-13-2008 04:04 PM
djohnston
10-03-2002 07:38 AM
