Sponsored by: Sake Bomb
May have solved the Stock Spring Rates Mystery !
Old 08-11-2008 | 05:33 PM
kjalleda's Avatar
Default May have solved the Stock Spring Rates Mystery !
I tried to get the best explanation for the correct OEM spring rates changes over the years after spending several hours looking for information, mainly because it was bugging me
According to Honda
00-01 to 02-03 ( The UK Press release states
Old 08-12-2008 | 05:57 AM
Elistan's Avatar
Good info, thanks. I agree, the correlation between SCC's measurements and the numbers Honda's percentage changes indicates a high confidence in those numbers.
That roughly corresponds to 7 kg/mm front and 6.25 kg/mm rear for the CR.
Old 08-12-2008 | 08:10 AM
s2kBryan916's Avatar
So that's why my cr is so stiff.
great post. This should be a great thread to reference to.
Old 08-12-2008 | 09:23 AM
Hockey's Avatar
or this one for example
Official Springs Thread
Old 08-12-2008 | 02:07 PM
s2ka's Avatar
The CR shocks are significantly stiffer than the stock shocks, that makes a difference as well.
CR Front: Damping Force Increased 50%
CR Rear: Damping Force Increased 32%
(from 2008 spec)
Check your tire pressure, it's not uncommon to see 45psi from the factory.
Old 08-13-2008 | 01:12 AM
JstnRyan's Avatar
Maybe you missed it. That was the point of this thread. The thread you linked to has incorrect information. The OP was trying to clear that up.
Old 08-13-2008 | 09:05 AM
s2ka's Avatar
Honda had published that the 02-03 had 20% stiffer front springs and 10% softer rear springs, so there isn't that much of a mystery. The UK information is probably only talking about the front springs.
The sway bar rates are easy, you can find them in the parts section at the dealership.
Old 08-13-2008 | 09:54 AM
iDomN8U's Avatar
good work
Old 08-13-2008 | 10:07 AM
AP2Berlina's Avatar
good information
Old 08-13-2008 | 11:52 AM
kjalleda's Avatar
I am sure everybody on the board including myself would be delighted to know if this is true, as it simply takes the ubiquitous guesstimate about the 02-03 spring rates out of the equation.
Anyway I am also sure that this information you posted about the % change in the 02-03 spring rates is news for the majority of us, and I hope its true, but could you kindly point us to the source of that information?
-Kishore
Quick Reply: May have solved the Stock Spring Rates Mystery !
