Lowering 1"
Lowering 1"
I'm thinking about lowering my car 1" mainly to eliminate the gap between the fenders and tires. I'm running Axis 18x9.5 rear / 18x8.5 front, with 225/40's and 255/35's (F/R). If I install a set of Eibach springs to lower it, will I need to modify anything else to keep from rubbing?
And are the pro kit springs a good choice for this car?
What would be a good place near VA to have fenders rolled? I may discard the idea entirely unless I can find someone who for sure has done this without error.
And I think the offsets are 45 front, 50 rear, but I could be wrong. Axis Halo, going by what the site says.
Post in your local subforum for where to get them rolled. What offset are the wheels? I feel like you need to roll them with those widths but it all depends on offset. If anything I'd say roll the fronts.
^ Car looks nice btw.
I'd be willing to bet your wheels are significantly heavier than stock... that might affect performance a bit as well. Wider, quality tires obviously means more grip, but heavy wheels might make the car feel a bit sluggish.
I have 17x9 +65 (255 tires) in rear and 17x7.5 +48 (225 tires) up front, lowered an inch (Swift Sport Machs, now Tein S Techs on stock shocks), and have never rubbed. They're lightweight Volks too, so that helps.
I think the potential issue with your setup is more wheel size related than it is lowering an inch.
myridechanelle
03-08-2008 02:54 PM
