Left rear caliper won't screw back in
No it's off, I even opened the brake bleeder screw and that didn't help. I did finally get it back in but it took a lot of force. The other side screwed back in easily. The weird thing is the caliper has not been giving me any issues.
i had the same problem. my passenger rear locked up so i got a replacement from autozone. when I tried to install it the piston wouldnt go in. i got another replacement and it went in no problem. maybe a bad caliper?
You might have some corrosion or deposits on the piston walls, I've also seen that happen with a bad piston boot that got bound up with the piston and made it difficult to move.
