Koni Yellow install..
Hey I'm currently in the process of installing Koni Yellows. I've read up on a DIY but it doesn't answer all my questions.. does anybody have a diagram of where all the Koni supplied parts and stock parts go, pretty much how exactly does it all go together...Thanks!
I hope this helps.
Didn't you get any instruction sheets with the Koni's?
As far as I remember the position of the bushings etc. is almost "one way only".
You do have to drill out the rubber bump stop to 12mm IIRC.
