Koni bumpstops
Koni bumpstops
I have a set of Koni shocks I want to put on the S, and figured I'd replace the bumpstops while I was in there. Koni lists a bunch of different part #s, but the descriptions are... well, vague is putting it nicely. Anyone have any recommendations for a street car on OEM springs, with a few autoxs thrown in?
The stock bump stop is very long. It is essentially in contact when the suspension is loaded, which is good for extra spring rate. Cellasto, is what its made of (http://www2.basf.us/cellasto/), but our little expert buddy knew that. It has strong resistance to losing rate but there is no chart for that degradation, which it does. So for the cost replace it with something that will give you some travel. http://www.ground-control-store.com/...tion.php/II=10 I use the stiff, linear version. This a better match to that shock.
usmarinedelta
10-02-2015 07:42 AM
