Intermittent ABS light
Seems like ever since I went to Kpro I now have an intermittent ABS light (though I know it's probably a coincidence). It comes on every half dozen starts and will go away once you turn off the engine. Will it still show the CEL if I jump the ECU? I figured it wouldn't since the code isn't there all the time or after you turn the ignition off and then back on.
if you have a nicer scanner. it should show the code stored as history. typically it can only be accessed by a honda dealer though. they try to keep a lock on software. simple check would be for a dirty sensor or obstructions to the sensor.
