I need new pads and maybe rotors
Yesterday I noticed that chirping noise coming from the indicator of my left rear break pad. looks like it has about 30% life left but I don't want to listen to that thing anymore. Anyway I am kind of clueless when it comes to breaks. A year and a half ago I replaced my front solid rotors with vented rotors and the pads with performance street pads. These pads http://www.tirerack.com/brakes/brake...+Pads&cat=Pads
and these rotors http://www.tirerack.com/brakes/brake...1&autoModClar=
should I get the same for the rear and are the rotors needed? I just remember the rotors on the front were a pain in the ass to get off. They came off quick because my friend was a mechanic but he had to drill out the locking screw on the stock rotors, heat the rotors with a torch, then used this special tool to knock it off. It was on there for 10 years and fussed on there pretty good.
I just need suggestions on what to get. I drive the car hard on the street and maybe autox on occasion. If I ever track the car ill put track pads in for the day.
Your rotor choice is fine. I haven't heard much about those pads, but if you liked them then stick with them. Another alternative would be the Hawk HPS.
A side note: You might want to consider checking your brake lines and your brake fluid if you haven't in a while.
I did bring it in to get a brake inspection just to verify it. They just told me what I had assumed. Rears are almost gone. They said the rotors were fine though. I didn't realize that the stock rear rotors weren't vented though but it appears that the aftermarket rears are solid as well. I am thinking I might just keep the rear rotors and just replace the pads since the rotors are still in spec.
Would it be ok if I just replace the pads? Id save about $100 by not getting the rotors. But more importantly I don't want to take off those stock ones because I know they will be a bitch.
Get OEM pads, they're better than 90% of aftermarket street pads.
tk416
11-18-2009 08:25 AM
