How to route new brake lines without ABS module.
Hello I looked everywhere but couldn't find any info on how to route brake likes during ABS delete... Any body with experience on abs delete?
Maybe regulations? Maybe his modulator is wasted. Either way routing brake lines as convoluted as ours is no easy task. Furthermore the master cylinder only has 2 lines, so you would need a combination valve to replace the proportioning valve. If you're going to go that route I would replace the master with a true tandem master cylinder. That way you can control brake bias.
You would have to bend your own lines using the factory lines as a template. But you would also need to be creative with how you route the lines after the combination valve.
Mr. Eryozgatliyan
06-22-2006 02:21 PM
