How to improve the springs on the car?
Originally Posted by s2000Junky,Jan 14 2011, 10:58 PM
ok
The lession here is, I read about flat ride on the internets, I found the original paper online and read it, then I tested the theory out and proved that it was still valid.
There should be more testing and less sharing subjective opinion about damper performance in this suubforum.
Listen its not rocket science. A softer spring rate will offer more compliancy over bumps which is what the OP is talking about here, and so will less compression damping yes. Finding a balance between this comfort and performance is what it comes down to. You can analyze it all you want and try and achieve the right balance for you, but saying adding stiffer springs to add softer more compliant bump response for a smoother ride is counter intuitive and poor advice.
Wrong, wrong wrong!
This is what I'm talking about. What is your experience? I told you mine. I did the experimant. Ride comfort has nothing to do with sprig rate. It has everything to do with ride frequency split. A higher rear ride frequency will offer a more comfortable ride.
You can argue all you want, but my statement, backed by research and proven through actual application trumps your opinion.
