Sponsored by: Sake Bomb
How to improve the springs on the car?
Old 01-14-2011, 10:36 AM
hook3549's Avatar
Default How to improve the springs on the car?
Hello
I have been riding my S2000 for a while and I always wondered how I could improve the springs on my car.
Every time I am in a neighborhood with bad road or go through the bumps, I can seriously feel it with my body and the car is about to break if I speed it up even a little bit. I know that S2000 is not supposed to be smooth like other cars but I really want to have even a small amount of smoothiness when I am in a bad road.
Is there any way I can change the spring or do anything to make it smooth?
Old 01-14-2011, 10:40 AM
s2k dre's Avatar
Ur struts might be getting old. With stock suspension and good tires the car rides pretty smooth.
Old 01-14-2011, 10:44 AM
hook3549's Avatar
the car is very smooth in the normal road, but as soon as I go through the bump, I either have to slow down to very slow speed or the car goes very hard
Old 01-14-2011, 11:55 AM
User 121020's Avatar
Worn out or leaking dampers typically make less damping force than new ones. I've always felt like the stock AP1 dampers created a pretty harsh ride.
OP, springs will not make much of a difference in the ride quality. Ride quality is largely a function of the damper characteristics.
Old 01-14-2011, 12:54 PM
SineS2000's Avatar
Well, this is not comfortable car at all, and never will be. Softer tires can help. I changed RE050 OEM with Toyo T1R and ride is much softer but still hard core. That's S2000 after all.
Old 01-14-2011, 01:56 PM
robinson's Avatar
Stiffer rear springs and digressive bumb damping make for a smoother ride.
Old 01-14-2011, 07:07 PM
s2cho's Avatar
Old 01-14-2011, 07:55 PM
s2000Junky's Avatar
Let some air out of the tires.
Cant do much else other then switch to a single ply sidewall tire to make more compliant, but then it will handle like shit. Always going to be a compromise between comfort and performance in this car. Its a light weight, stiff chassis car with a short wheel base.
Old 01-14-2011, 07:58 PM
s2000Junky's Avatar
ok
Old 01-14-2011, 09:31 PM
realblag's Avatar
Did you buy the car used? Is it at a factory ride height? Is it still on factory shocks/springs? Will the car move significantly if you press down with your hand on the rear quarter?
Quick Reply: How to improve the springs on the car?
