How to diagnose potential bent suspension arm?
My rear driver's side won't dial out hella camber without making the toe some crazy unthinkable spec. I asked a few friends to help me try to figure out what it is but they basically end up saying something along the line of "start replacing things and eventually you'll fix it". I've never wrecked the car, so I don't get why...gr. Could it my lower control arm? I have no idea what it is and I have no idea what to even do. Do they make magical machines that can tell me?
I would check it on more than one alignment machine some places machines are very out of whack.
Also make sure they have someone that knows what they are doing with the alignment.
I mean its normal for toe to change with camber but then you should be able to dial the toe back to where you want it.
If there is something bent the main suspects would be the upper or lower control arm or the toe-arm thing or any of the bushings.
Upper control arm looks more bendable than the lower and its not too hard to change so you might want to start there
If you can find one cheap corner you might try doing the whole thing (knuckle, control arms, driveshaft etc) and putting it on rather than changing them all out one by one and messing with ball joints it might be easier.
Me and my buddy whos a mechanic changed the left rear corner at the track in less than an hour like that.
Guess it's time to find a parts car in my area. car-part.com rocks!
ever whack into a curb or nail a deep pothole?
I had the same issue after sliding into a curb (mental note, take off summer tires before December ) and bent the LCA and knuckle.
There is a way to check, but I don't remember the science of it. Involves using a lift and having the car raised up so that you can inspect the "squareness" of various control arms.
james0933
08-18-2014 03:12 PM
SoCalIsMyLife
09-11-2008 06:30 AM
