Sponsored by: Sake Bomb
Help with koni coilover install
Old 04-25-2012, 07:55 PM
  #21
macr88's Avatar
Ok depending on valving I should be able to say whether you'll be bottomed out in the corners or not but right now it's not looking good with the MX5 bar or the AP1 bar for that matter
Best to wait for the dyno before I really say.
Old 04-25-2012, 07:56 PM
  #22
macr88's Avatar
Oh can you also measure the distance from hub to fender with it at full droop.
Old 04-25-2012, 08:01 PM
  #23
Ayge's Avatar
Not looking good meaning an inch of travel won't be sufficient to keep it off the bump stops?
Old 04-25-2012, 08:04 PM
  #24
macr88's Avatar
Correct at least so far it's not looking good.
Old 04-26-2012, 04:32 AM
  #25
Ayge's Avatar
Fronts
Rears
Old 04-26-2012, 07:30 AM
  #26
macr88's Avatar
Since there aren't any values it's still a guess
I'm guessing even if you ran full firm on the compression you'd probably still be bottomed out in the corner.
The sure way to know is either mount a camera or you can put an o'ring on the shaft (make sure the diameter of the o'ring is large enough that it won't get pushed into the wiper seal) drive through a corner and see where the o'ring is at.
lex2go
04-25-2017 02:33 PM
hey32g
03-02-2013 10:45 AM
s2keddy
04-22-2010 05:39 AM
XLeezardx
10-18-2005 07:54 PM
ninja.s2k
11-10-2004 07:23 AM
Quick Reply: Help with koni coilover install
