Sponsored by: Sake Bomb
Help with koni coilover install
Old 04-20-2012, 09:49 AM
macr88's Avatar
Originally Posted by Ayge
After lowering the sleeves and bottoming out the perches, I'm down to 13". Was hoping for 12.5", but it is what it is. Thanks again for the help.
Thanks for the update bummer about the height. Did you loosen the upper and lower control arm on the rear then jack up to ride height then tighten? If not then you'll want to do this so the bushings aren't stressed.
You might also be able to get a ya lower as well depending on the condition of your bushings.
Old 04-20-2012, 03:45 PM
Ayge's Avatar
Originally Posted by RedCelica
OT: How much did the revalve cost you?
I got the Phase 3 from Truechoice, revalve was included in the package. I *think* the revalve alone is around $115.
Originally Posted by 06Estukay
Try running shorter springs. At those spring rates, you could easily go down to a 6" spring. Try a 7" spring first and go from there.
I may try that in the future, though I will definitely need spring tenders at anything less than 8".
Thanks again for your help. I preloaded the UCA bushings as you described and the lowers should have been taken care of with the alignment.
Old 04-20-2012, 09:18 PM
macr88's Avatar
Spring length and tenders have nothing in common, it's spring rate and droop that determine how much play the spring will have between perches.
The lower front bushing doesn't get touched at the alignment shop but the one in back does.
You're very welcome
Old 04-23-2012, 04:26 PM
Ayge's Avatar
I've driven about 100 street miles and done one autocross since installing them, for the most part they feel great. It doesn't bottom out at all, so it's not nearly as harsh as I would have expected given the spring rates. I have noticed, however, that the rear feels bouncy over rough pavement at slow speeds (~25 mph). I tried increasing the rear rebound, but it seems to make it worse. Valving issue? or just the nature of what are essentially track spring rates intended for smooth pavement?
Old 04-23-2012, 04:51 PM
macr88's Avatar
did you try decreasing rear rebound to see what happens?
Old 04-25-2012, 02:46 PM
Ayge's Avatar
I was reclocking the suspension bushings just to make sure I didn't miss a corner. I put the front of the car on jack stands, then jacked up one of the front control arms until the spring compressed and the car lifted off the jack stand. Am I correct in that this is the ride height? I noticed that there is zero room between the bump stops and top of the shocks. If I'm thinking about this right, the car is riding on the bump stops all time time.
Old 04-25-2012, 04:28 PM
macr88's Avatar
Measure from the hub to fender just like you would to get ride height and jack it up to that point.
Once you have it jacked up to the ride height measurement then take a look at your usable travel.
Old 04-25-2012, 07:03 PM
Ayge's Avatar
Jacked up the control arms and measured as you suggested and confirmed that the point where it lifts off the jack stand is the ride height. That said, I also confirmed that I had no suspension travel as it was statically on the bump stops. I cut about 5/8" off the fat end of each bump stop and flipped them around. Now has about 1" travel. I don't think I need to worry about bottoming out the shocks with these spring rates. Hopefully this takes care of the bounciness.
Old 04-25-2012, 07:29 PM
macr88's Avatar
Are you running a rear bar?
Do you have the dyno's for your dampers
Also is the inch in front or rear or both?
Old 04-25-2012, 07:41 PM
Ayge's Avatar
Running the stock AP1 rear bar for now. I have an MX5 front bar that I'll be installing this weekend.
I have dynos for the dampers, though to be honest I don't really know how to read them. I can post them tomorrow.
The inch is both front and rear.
Thanks again for all your help!
Quick Reply: Help with koni coilover install
