help on coil overs
help on coil overs
Hi guys im hopeing to lower my car soon and im not to sure which coil overs to go for and how low to go.
Is there a limit is there anything i will need to change apart from the coil overs
and what bolts etc do you guys think i should order as spares before i start taking the standard ones apart
any help and advicce appercaited thanks
What is your budget and what are your goals? If you're only after a drop and ride on the street, get lowering springs. More than likely, the budget $1000 coilovers perform worse than stock.
