Help ! Brake problem :(
Hello guys I recently got my rear brakes changed and experienced no problems for a couple of weeks. About a week ago I noticed a weird burning smell and when I finally parked and investigated what it was I noticed my Driver Side rear rim was hot, to hot to even touch without burning your hand. I drove around for a couple of more days and the driver side rear rim was perfectly fine until it happened again. I tried to rule out if it was an ebrake problem by not using my ebrake at all. I noticed that the days I put my top down Id get the smell from that wheel of the car so I was either thinking it could be the ebrake sticking or a seized caliper? But then today the same thing happened to the other wheel ( passenger side rear ). What do you think the problem could be?
1 Post
Sounds like he said it was two different wheels. Id guess your brake fluid may need a change? Ever changed it? Maybe its the calipers, but unless i misread and its only 1, i doubt 2 are goin out at once
