Grippier pads up front
I'm in need of new front pads shortly. I was interested in the Carbotech 1521's, which are "grippier" than the OEM pads. Will I have issues putting a more grippy pad in the front but not in the rear? The rears don't need replacement, but if they did, since they only do like 25% of the stopping, I would consider OEM pads for them.
Thoughts?
Thoughts?
obviously the front handles more of a load under braking, but brakes are designed to be balanced in such a way that both fronts and rears are maximizing their braking ability relative to the weight they are supporting. simply upgrading the front pads may not make too much of a difference but in general it's best to upgrade the front and rear together to retain the intended braking balance. if you are up for some reading here is a great article on the subject!
http://www.stoptech.com/tech_info/wp...formance.shtml
merkis1024
12-29-2014 06:57 AM
DangerZone9K
01-05-2011 05:28 PM
