GC top hat discussion and general info on increasing bump travel
Yes, the Penskes use a 12mm pin mount that is about 60mm long, if I remember correctly. The pin mount then threads onto a 5/8-11 male thread on the damper shaft and is held in place with a thin jam nut. I've got a CAD model of it all somewhere...just can't find it.
What are the dimensions of the Ohlins pin mount design? The GCs are indented to be used with OE (10mm pin mount) or Koni dampers (12mm pin mount). They just happen to work with Penske pin mounts, as well. The Ohlins look like they have an extra step in their pin design, so they may require a custom spacer to work with the GC top hats.
whats the exact model/year/version of the extended hats?
I have revalved konis, shortenned fronts with 700/600lbs springs but the rears where bottom out so I had to raise it up all round (or run a not sensible amount of rake)
Bingo. If you ask them about these mounts for an S2000, they'll probably tell you they have fitment issues, which they do slightly. You will experience rubbing on the fuel filler bellows. They will probably cause slight rubbing on the hood liner in the front.
The GC SKU for these mounts is "HondaMount-RACE". Not exactly a number, but they'll know which ones you're talking about. Specify the 12mm pin mount when using them with Konis.
I talked to GC and they said these are the ones for the rears: http://www.ground-control-store.com/...ion.php?II=642
Any model
Any model
/Steve\ used the polyurethane version in his writeup. The ones I used (above) are the spherical bearing version.
Any model
Any model
http://www.ground-control-store.com/.../II=743/CA=188
http://www.ground-control-store.com/...ion.php?II=779
Which year, and Civic or Integra?
Or did you just want the spherical bearing? What benefit does it provide over the urethane one, just running it in the back? Does the bump stop/shaft body fit up into these with Konis, how low of a ride height are you able to achieve without bottoming?
