Sponsored by: Sake Bomb
Front driver wheel sitting on an angle after repairs.
Old 05-07-2012, 09:45 AM
Peterc86's Avatar
Default Front driver wheel sitting on an angle after repairs.
Not sure why the hub has been changed as far as I know. I got an alignment and they said they couldn't get it into spec. The car drives fine dosent pull to a side but it bothers me to no end. What could it be? Bent frame? The bodyshop assured me there was no frame damage and it wasn't a head-on collision or a t-bone..
Passenger side sits perfect
Old 05-07-2012, 03:33 PM
RacerXI's Avatar
Got an alignment spec sheet? It looks lowered also. Is that the case?
Old 05-07-2012, 04:40 PM
Peterc86's Avatar
Yes I have a sheet I will try and get it from the shop tomorrow. I wanted to know if this is possible due to frame damage? It could be that the bodyshop guys lying to me.
Old 05-07-2012, 10:48 PM
robinson's Avatar
What repairs were done? It's not clear in your first post what happened.
Old 05-08-2012, 05:16 PM
speedjunky01's Avatar
if the subframe was unbolted it can move quite a bit my steering wheel was even off a good bit after the clutch job.
I unbolted the 6 subframe bolts, pushed it so its centered, tightened down and it is ok now
Old 05-09-2012, 03:28 AM
Back S2k's Avatar
whoever did your alignment dosent know what they r doing. if nothing is bent wich it shouldnt b considering everything was fine b4 the hub was changed. the centric bolts could be installed improperly.
Old 05-11-2012, 02:17 PM
thomsbrain's Avatar
If it can't be aligned properly by a good technician, then you still have bent components in the suspension, knuckle, and/or a shifted or bent subframe.
When I needed repairs, the first body shop said everything was perfect after replacing the control arms, but I had a ride height issue and the car wouldn't align to spec when I took it to an independent alignment shop. A second shop ended up needing to replace the knuckle and the entire subframe to get the car back to new.
If you went through insurance, re-open your claim and explain that the car doesn't align to spec after the work done by the shop. Request another shop. They may need to have their adjuster come look at the car again, but the law says they have to repair it to like-new condition, so they can't just call it "good enough."
Old 05-20-2012, 08:30 AM
Peterc86's Avatar
It's been 2 years not sure if that will work
Old 05-20-2012, 09:48 AM
S2Ko0o's Avatar
You waited 2 years with it like that?
Old 05-20-2012, 02:08 PM
Peterc86's Avatar
1st year got it back and went right in the garage this year I took it out finally because of insurance reasons I didnt want to drive the previous year rates would have been really high.
andrewhake
46
10-31-2014 09:40 AM
KyungMin
06-17-2014 01:07 PM
pikkashoe
05-11-2006 08:59 AM
Rio S2K
03-18-2005 03:15 AM
vananron
32
02-20-2004 01:29 PM
Quick Reply: Front driver wheel sitting on an angle after repairs.
