Sponsored by: Sake Bomb
Found my first manufacturing defect
Old 11-20-2010, 06:16 PM
vjarnot's Avatar
Default Found my first manufacturing defect
So I took all the control arms off the car to replace the bushings. I was finishing up the re-assembly today.
Got the right front done, and move to the left front. Lower arm went torqued down just fine, torque the front bolt on the upper arm - no problem; started tightening the rear bolt and my luck turned sour. Bolt got to about 30 ft-lbs and spun the threads right out of the nut. Now that I reflect on it, I'm not sure what exactly was holding that bolt in for the last 8.5 years.
The beauty part is, that nut is welded on... I got a 12x1.25 replacement nut, but I'm undecided as to whether or not it's worthwhile to weld it to the control arm bracket... thoughts?
Anyway, to preempt the inevitable comments regarding torque wrenches. Yes, my wrench was set to 76 ft-lbs. Yes, I know torque wrenches can suck. This is a Proto wrench which came with a calibration certificate, 76 ft-lbs is damn near to the middle of its range. Yes, I know brand-whores go for Snap-On, but I'd place money that a Snap-On wouldn't be any better (if it were as good) as my Proto.
Anyone else see a similar failure?
PS Strangely enough the rear get 20 ft-lbs more torque - same bolt, but beefier nut in the rear.
PPS Yes, I did just write "nut in the rear".
Old 11-20-2010, 09:32 PM
Slows2k's Avatar
If you can get a wrench on it I wouldn't bother welding it.
Old 11-20-2010, 10:15 PM
vjarnot's Avatar
My thinking as well, especially given how close it is to the brake (hard) line.
Old 11-25-2010, 09:07 PM
zeroptzero's Avatar
Received 3,678 Likes on 2,611 Posts
see my reply in the other thread , replacement parts listed.
s2000maniac
03-10-2014 03:09 PM
bruthaboost
09-10-2013 08:03 PM
driftnby
02-16-2008 02:08 PM
Joel S2k
03-27-2006 11:10 AM
Mirror
08-18-2002 11:21 AM
Quick Reply: Found my first manufacturing defect
