Does Origin Offset Bushings fits on HKS Hipermax S?
As the title says, do the Origin offset bushings fit on HKS Hipermax coilovers?
I just installed the HKS coilovers today but completely forgot they have the helper spring.
The clearance between the arm and the coilover collar seems extremely close.
Has anyone installed the Origin offset bushings with the same coilovers? If they don't fit, I am planning to switch to J's Racing lower joints.
The control arms are very close to most coilovers that run standard diameter springs and offset bushings. They are not as close as they look once you have the car at height, but to make sure, you can just put a jack under the balljoint area of the control arm (right under the balljoint) and jack it up until it just starts to lift off the jack stand, and see how much clearance you have. It will actually have a bit more as the spring compresses so you can get a good idea of contact by doing this. But you should be fine.
My coilover setup uses 2.5 inch ID hyperco springs, and 2.5 inch is pretty common. I run the baero offset bushings and have no clearance issues. It looked super close when I first installed but they work great.
ArchdukePoland
05-24-2023 06:32 PM
