Coilover is stuck :(
I recently just purchased some coilovers and decided to put them on today. I was able to easily adjust 3 of them but the last one was just STUCK. i tried spraying some wd 40 and liquid wrench but still no help.
any thoughts??
Regards,
Tuan
any thoughts??
Regards,
Tuan
what do you mean by STUCK?
what's exactly stuck on it?
is it on of the height/spring perches?
what coilover is it?
do you know does it have aluminum or steel body?
i did try two spanner wrenches and a flat head with hammering to adjust the ride height but it doesn't move. one of coilover on the rear left makes this cracking noise whenever i drive on it, its constantly. i try adjusting the dampering settings (top notches) but it also really hard to twist compare to the 3 other one. i have godspeed rs coiloverrs
any help will be much appreciate thanks
Originally Posted by spets,Oct 14 2010, 01:20 PM
are both sides (L/R) jacked up when you're trying to adjust? If you only jacked up one side the swaybar is going to be fighting you.
yeah i did everything correct. the cracking noise is less now after i finally be able to adjust the dampering settings. i had it all the way down at soft. i think thats the problem.
masterthl
06-05-2008 12:09 PM
